1 - 13 of 13 Posts
The White Jeff W
If you're not familiar with the Retro Ryder headset, it allows you to run a fork with a 1 1/8" steer tube on a bike originally equipped with a 1" steerer fork. I posted in the cruisers thread that I had gotten one for a klunker project and someone asked me to document the install, so here it is.
First, here's a link to the Genuine Bicycle Products website, where the RR headset is available. Genuine Bicycle Produsts: Parts and Accesories.
As for the install, it was pretty much like any other headset I've done. The fork I used is not the one that will go on the bike, but it's all I have right now. I should add that the crown race on the fork is not the one that came with the kit. There was already a star nut in it so I didnt include that in the post.
Here's everything that came in the box
Cups & Bearings
Crown Race, Compression Ring, Top Cap, Upper Bearing Cover
Star Nut, Lower Seal, Upper Seal, Top Cap Bolt
First, grease the bearing cups and install in the frame using a proper headset installation tool
Install the crown race, dust seal and greased bearing on the fork
Install the greased upper bearing in its cup and slide the steer tube through
Slide the upper bearing cap and seal over the steer tube
Then the compression ring
Headset spacers and stem and top cap are next. When you tighten the top cap it will compress the upper seal under the compression ring so make sure you have enough spacers to allow for proper preload. Tighten the cap screw until all the play is gone and everything turns freely, then square up the stem and tighten its bolts.
Enjoy your new klunker. Head angle with a 80mm fork sagged 20% is 69 degrees. Money :cool:
Master of the Face Plant
Another option is to find yourself a used 1 1/8 inch sealed bearing headset like a King or Cane creek and send it to Products. For 17 bucks he will turn it down to the proper diameter. Maybe a better option than paying $45 bucks for a $10 dollar headset that some guy put on a lathe.
The White Jeff W
Discussion Starter · #5 ·
Good idea. We had an old metal lathe at work. One day I came in and it and a bunch of other stuff was gone. New owner cleaned house. Chucked it in a dumpster over the weekend, along with a drill press that also would've looked great in my garage.
Thanks for the writeup! I have been looking for options to upgrade my Klein Pinnacle and this looks like it might be the ticket.
Premium Member
Does your pinnacle have a rigid fork because if it does, then it's debatable whether it's an upgrade.
Love those park tools.
"Upgrade" was probably the wrong word to use. Resurrection is probably more accurate. The frame was given to me by my co-worker that has a special talent for finding bikes at the landfill. He spotted it in the scrap pile and in an instant even with a coat of black spray paint and a coat of olive drab house paint on it. If it had the original fork and Mission Control Stem/bars I would be good to go.
Premium Member
Ah yes, bummer about that. :(
Sacrilege!...I don't mind a slack head angle, heck a DHR runs a 63*...But a modern sus fork on a PREWAR? I get heckled for running a freewheel round these parts.
Ride that here and you would have declining produce thrown at you.
Seriously, that is a cool headset! How about a replacement 1" fork though?
1 - 13 of 13 Posts
