And unless you powerwash your seatpost clamp you can ditch the center sleeve. Then I bet the weights get even closer.rockyuphill said:The $40 XTR BB is only 13gms heavier than the Reset. With one 2.5mm spacer they weigh in at 89gms.
will most likely last 4 times less. mortop is not very famous for its quality, you should know that. This also applies to other chinese and taiwanese stuff, like aerozine, prototype etc....Mortop BB uses almost the same cups with different bearings. It weights 82g for complete set and 68g without center sleeve and spacers and it costs 3 times less than Reset.
I'll let you know how my bb performs over time...I had such a BB on my commuter road bike. It gets used every day but doesn't get a lot of mileage. The Reset BB creaked pretty badly in less than a year. I wouldn't buy one again.
