Hi guys and gals, I would like to replace my rear hub for a better and also louder one. I have spoke with a few bike shops and hear some mixed responses. A few have told me that I need to replace the rim cause it won't stay true after assembly. Another has told me no problem just replacing the hub. I have a 141mm x 9mm qr. any ideas would be appreciated.
thanks,
Don't replace just the hub. I would do nothing, but if you can't resist the siren song of upgradeitis, replace the whole wheel.
-141x9mm is a weird OE budget response to all the through-axles. That's fine, but it indicates you have a budget-conscious bike build. Which is also fine. Bikes designed around a sharp budget won't have amazing hubs, but until a budget hub is problematic it's 99% as good as a fancy hub. And most riders won't have any problems with a budget hub. Err... i'm almost certain there's better places to spend your money. (i bet your bike came with a shitty fork, for example)
-It's reasonable to replace the rim. Why build a wheel with a cheapo rim and an expensive hub? Dumb. Also, reusing the spokes limits your hub choices and makes the wheel builder responsible for whatever BS the spokes were exposed to before he touched them.
-amusingly, the shop that tells you to abandon this endevour is probably the most experienced.
-the best hubs tend to be pretty quiet, along with the cheapest ones. Noisy hubs tend to fall in the middle. There's reasons for this and it isn't a hard-fast rule, but it's interesting.
IMHO. You do you!
