1 - 20 of 27 Posts
Hi guys,
I am restoring a '92 Klein Rascal and I have removed the integrated bottom bracket unit by using the original specific toolkit.
Here I show you the toolkit components:
And now...
- PROCEDURE FOR REMOVING A KLEIN INTEGRATED BOTTOM BRACKET SYSTEM
- Prepare the tools (page 25 of the Klein Tech Manual)
- Remove the crank arms. Record the current bottom bracket setting by measuring the total spindle length and the non-drive side setting (measured from the bottom bracket shell to the end of the Spindle).
- Spray the bearings area with anti-rust/penetrant oil for easy glide during the extraction process (take into account that rust, debris and old Loctite will difficult the extraction process)
- On the non-drive side, place spacer (I) over the spindle followed by the step washer and crank bolt (tighten crank bolt fi nger tight).
- On the drive side, place the rubber guide over the bottom bracket shell.
[will continue...]
Discussion Starter · #2 ·
- Now, slide the steel tube into the rubber guide until it is up against the bottom bracket shell.
- While setting up the main screw (important), maintain a well lubricated main screw during the entire procedure (a light penetrating oil is preferred). Thread on the driver nut all the way followed by the thrust bearing.
- Then place spacer (G) with the shoulders away from the thrust bearing, over the main screw.
- Now, place the entire assembly into the steel tube and thread the main screw into the spindle.
- Hold the main screw in place and thread the driver nut towards the bottom bracket.
- This continued action will extract the entire unit.
[will continue...]
Discussion Starter · #3 ·
- Next photos will show you in "slow motion" what happens during the real process, step by step. What you are going to see now cannot be apreciated on the real process because everything happens inside both the steel tube and the rubber guide.
- Almost finished...
- Finally, it is completely out of the shell!!
Hope it has been interesting for you!!
Mtn Biker Machinist
Holy CRAP!
No wonder they don't make press in bb's anymore! I love all things mechanical, and I love working on bikes, but that is ridiculous! How many times can you do that before the bb shell is too loose to hold the bearings in? Hopefully the bearings last a long time!
Your level of detail and documentation is outstanding. That took a lot of patience just to take all those pics. You should make a PDF and post it, I am sure all the Klein owners would love to have it!
frog
1 - 20 of 27 Posts
