Providing it’s a constant current style driver you’ll be just fine. Out of interest what driver are you using, and have you made a decision between the Cree XR-E and the Seoul Semiconductor P4?
Both emitters have their positive and negative aspects; basically it comes down to which emitter will suit your optic or reflector choice, and how you’re going to physically mount the emitter. You say heat is not an issue and while these emitters produce a lot less heat then previously available emitters, thermal consideration is still important for lumen maintenance, particularly at higher drive currents like this.
And by the way, an average Luxeon III emitter would be consuming a little bit more then 3 watts if driven at 1000mA, unless you’ve got an emitter with an extremely low forward voltage!
Let us know what you’re thinking! :thumbsup:
Cheers, Dave.
