I guess no one wants to touch this, bummer!
Thanks for the VERY encouraging post! Yes, the plan is to glue steel or titanium tubing into the crown and dropouts. It's obviously not that simple, which is why I asked the question. If carbon tubes can be glued, why not metal? It will require the right adhesive, which I have access to, and some way to work out the diameter differences.jay_ntwr said:You could just by a Salsa Cro-Moto and be done with it for probably less money and you'll get to keep your teeth. I mean, what's the plan here, just to glue tubing into the aluminum crown.
bikeny said:Thanks for the VERY encouraging post! Yes, the plan is to glue steel or titanium tubing into the crown and dropouts. It's obviously not that simple, which is why I asked the question. If carbon tubes can be glued, why not metal? It will require the right adhesive, which I have access to, and some way to work out the diameter differences.
What I really want to know is what wall thickness tubing would be appropriate for either titanium or KVA stainless in either 28.6mm or 31.8mm OD?
Mark
