The original fork on this bike is an RS Juxy XC with "long travel" 55mm travel if I remember correctly. I'm now going to get a new fork that will probably be transfered to a new frame.
I suppose a 80mm fork would be ok.. but I want something with 100mm travel (probably adjusted to max sag ?) to put on it. Would that make the angles all wrong ?
I will survive a little change towards better downhill stability..
Wondering about a Psylo or something else that can be adjusted from 80mm to 100mm travel if I can't fit a regular 100mm fork on the frame.
(converting from 1 1/4 to 1 1/8 using spacer, new headset and stem)
