I think the pedals I am using are called PD-M731 pedal. They are from the late 80's early 90's. I have been using them since then and love them. But they are starting to wear out and would like to get a new set if possible. I saw some on ebay for $85 but I thought I would check out if any modern pedals can serve me better.
The reason why I like these pedals so much is becuase I use the power grip system and also I like that the pedal is the same on both sides. So 98% of the time I am in the straps but if I have to dab on a down hill or up hill I can just put my feet on the pedals upside down and they feel the same and when I have a chance I get strapped in again.
And not going to clipless so I am not looking at any clipless pedals.
Here are some sample pics, these are not mine but same stuff.
M731 pedal:
power grips:
For the powergrips to mount the pedal has to have the mounting holes for toe clips. That is the problem I run into when looking at modern flat pedals. Or the ones that do have toe clips aren't the same on both sides.
M731 pedal:
power grips:
