With full length housing you want guides, not stops.ebotto said:Is there any sort of aftermarket cable stop? Perhaps one that mounts to the cage mounting holes? I want to run full housing on my front derailleur and the only cable stop is up by the head tube.
Ahh..missed the front part. Top or bottom pull?ebotto said:Love zip ties but am looking for an actual stop like what's welded to the frame that can be attached to the frame so I have a stop at the end of the housing.
Thanks Shiggy. I tried something similar but when I shifted it pulled the housing along with the cable. I think there needs to be an actual stop at the derailleur end?
I believe it is a bottom pull. The cable runs along the downtube then underneath the bottom bracket. The frame is an '04 Specialized Enduro.shiggy said:Ahh..missed the front part. Top or bottom pull?
