Pistons can not go any farther back than they already are. The pads are nearly impossible to get back in. Developing mild case of tendonitis trying to do this....taking years off my life perhaps...AZ.MTNS said:Remove brake pads , push pistons back , replace brake pads .
When changing out old pads, the recommended way is to spread the pistons with the old pads in place to protect it..that's because it takes some force to spread the pistons apart, and the old pads will protect them from damage while you pry them open......I typically use a hefty flat-head screwdriver, the thickest and longest one in my toolbox, and I rock it back and forth using the edges of the caliper for leverage.....rydbyk said:Pistons can not go any farther back than they already are. The pads are nearly impossible to get back in. Developing mild case of tendonitis trying to do this....taking years off my life perhaps...
Pretty sure I am going to go back to my trusty simple mech. disc brakes. There was NO rub before I removed the pads today. They worked just fine. They were simply worn down is all.mullen119 said:Have you ever bled the brakes? sounds to me like there is too much fluid in the system and that is causing the pistons to not get pushed back all the way. You may need to remove some fluid.
that is exactly the problem. As the pads wear thinner the hydraulic brake automatically compensates and extends the piston further and further so the brake will still feel the same and engage as quickly as with a thicker pad.rydbyk said:They were simply worn down is all.
The reason I Like hydro's is once they are set up, You can pretty much forget about them. Good mechanicals have good power and feel, but I have found that you need to tinker with them. As I said in my last post, If you bled the brakes before(or had a shop do it) with worn pads, You can have to much fluid in the lines. There is only so much fluild that can fit in the system and if you bleed with worn pads, You add fluid when the pistons are pushed out some. That can cause the pads to not be able to be pushed back all the way. If the brakes have never been bled, they should be able to get pushed back all the way with a screw driver using the old pads as said above. If you can't get them figured out, take them to a local shop and have them do it.rydbyk said:Pretty sure I am going to go back to my trusty simple mech. disc brakes. There was NO rub before I removed the pads today. They worked just fine. They were simply worn down is all.
I just don't see the advantage for an XC racer to use hydros in So. Cal. You?
