Bike came with this hub:
Already replaced once due to Recall. Now they're worn again - bearings and ratchets - after 2 years of moderate use.
Per LBS, if I can get the 'guts' I can replace it w/out replacing the whole hub and re-lacing the wheel.
This isn't a common part number available online, and so I'm in contact with Novatec and Bikefetish (distributor) about buying direct.
Anyone have feedback on doing this? Is there a compatible replacement that will just swap in w/out replacing the whole thing?
Yes, I'm a newb on this stuff.
I'm running a 2x10 GX.Novatec / JOYeTEC D342SB-SL-B12 ALLOY REAR MTB DISC HUB, 12x148MM, 32H, D:45.9MM FOR SHIMANO 11 SPD COMPATIBLE, 4 SEALED BEARING
