Replace just the blade on M401 brake levers?
743 Views 3 Replies 3 Participants Last post by  bad mechanic
My bike came with Shimano M401 brake levers, and I want to upgrade to the more on-off feel of Servo-Wave levers. Does anyone know if I can replace JUST the lever blade itself on them, or if I need to replace the entire brake lever assembly?
Basically, just swap this onto them:
1 - 4 of 4 Posts
I've not used non servowave brakes for years but I have took my SLX levers apart.
Those lever blades aren't anywhere near compatible as the design is so different.
You might be fine with a two finger lever blade off one of the other non servowave models, i.e. M395's as one example.
You're looking at needing to replace to a full servowave lever otherwise.
If you don't care about the tool less adjuster or the free stroke adjuster than why not just get a new deore BL-M6100 lever. Personally I prefer it over the SLX or XT as I have found the removal of the freestroke I never used to result in faster better bleeds. I actually think they are more svelt with with lever reach adjust being a screw rather than a knob.
Here is the best part you can some times find them for 29 dollars each. Which is about the same as a lever blade. I made this discovery after snapping off an slx lever blade and pricing a replacement.
The deore and SLX lever blades are about the same. The Xt may be stronger.
I also found the non replaceable plastic bushing deformed so a new assembly was a better move for me than a new blade as it would have had slop.
I would, and I tried, but I can't find them in stock anywhere right now.
1 - 4 of 4 Posts
