Depends. Cost of a set of chainrings can often exceed a whole new crank crazy as that seems. Then there's the possible additional cost of a bottom bracket you might need. You might look at a new external type crank that comes with a bottom bracket for cost effectiveness. Do you even know if both those square taper cranks use the same length spindle on the bottom bracket? They're not all the same, didn't look it up myself...
