I need to remove this bushing so I can slide the air can off. Does this require a standard bushing removal tool?
That's not a bushing, that's a pin or axle. The bushing is the thing that it rotates on, in between the pin and the shock body. You don't need to remove the bushing to get the shock can off.I need to remove this bushing so I can slide the air can off. Does this require a standard bushing removal tool?
So you just use socket to catch the axle has you hammer it out? Basically just using mallet to drive the axle out of bushing? No special tools required?Deep dwell socket on one side that clears the pin but sits flush on shock shaft. Rubber mallet on pin....smack it out into socket. Complete smacking out with a socket that sits just inside the bushing..
Yep, the socket holds the end of the shock shaft (flat part), keep it square when you tap on it, the deep dwell socket should have enough room inside to catch the entire axle so it doesn't bind up.So you just use socket to catch the axle has you hammer it out? Basically just using mallet to drive the axle out of bushing? No special tools required?
And to get it back in you just use mallet again and tap it in?Yep, the socket holds the end of the shaft, keep it square when you tap on it, the deep dwell socket should have enough room to catch the entire axle so it doesn't bind up...once the axle is mostly out and you cannot tap on it anymore you may need another socket that would fit inside the bushing so you can tap it the rest of the way out.
You could also use some of some of the methods described above to get it out the remaining amount. Just depends how tight that sucker is.
Don't get all ham fisted banging it out, should not take too much force you don't want to damage the axle.
I have use a vice with sockets, or you can use a bolt with washers and sockets.And to get it back in you just use mallet again and tap it in?
