Is there any way to get the back wheel [with disc rotor] off without scratching the frame bending the rotor or going nuts?:madman: :madmax: Why so hard? Someone please tell Me if there is a easy way to do this........
It shouldn't be that hard. What is the problem? Can you loosen the axle/quick release? Push the wheel out of the dropouts? The other place the wheel sometimes gets hung up is at the rear derailleur - you may need to pull the derailleur back out of the way, and then the wheel should drop free. It's easiest to do this (and put the wheel back in) if you shift the chain to the small rear cog first.mr.specialized said:Is there any way to get the back wheel [with disc rotor] off without scratching the frame bending the rotor or going nuts?:madman: :madmax: Why so hard? Someone please tell Me if there is a easy way to do this........
This is definitely not the way things should be! The rotor is on the opposite side from the derailleur, no? Not sure why/how it is in the way of the frame and the derailleur. Also, the quick release shouldn't really be in the way. HOWEVER, on one of my bikes the derailleur itself encroaches a bit into the dropout, so it can take a bit of pressure to force it past. I wonder if that's what's happening to you? You need to figure out exactly where the wheel is hanging up.mr.specialized said:I did shift to the smallest cog but the problem is there is no room for the rotor to fit in between the frame and the derailieur. I had to take the caliper off the frame and the quick release rod out just to get enough room to pull the wheel :skep:
This is how I do it...mr.specialized said:I've allways had rim brakes so maybe I just need to learn how to do it right.....but what's happening is when I pull the wheel from the dropouts there's no room for the rotor to clear the frame when I move the wheel over to clear the deraileur, then it gets stuck and I end up going nuts because I'm scratching up the frame....And no I'ts not a sram it's a xt....
