1 - 2 of 2 Posts
Appoligies for what what might sound like dumb problem but i need some advice.
I have XT breaks, and I removed the front wheel put the bike in my car, lying on it's side and drove for about 5 hours. When I went to put the front wheel back on I found that the break pads had closed in and couldn't get them wide enough to fit the disk back between the gap of the pads.
:confused:
Before I go using hard metal objects to force these pads apart, is there any good advice ??
thanks
Donal
Get your freak on!
:confused:
thanks
Donal
Stick a clean flat screw driver in there and slowly wedge the pads apart. If your worried about the pads, then removed them and use something like a plastic tire lever to push the pistons back.
If they were pushed too far out, they may require a bleed:(
1 - 2 of 2 Posts
