It's not hugely different.
The drop outs and abp axle are narrower this year (on the outside edge, still 135mm internal spacing),
It has iscg-03 mounts, which the 09 doesn't.
It also has a slightly different rocker link, with a larger cutout at the front to accommodate the drcv shock, which is taller than the RP from last year.
Built up it comes out about 1degree steeper head/seat angle than the 09, which is because the 32 is shorter than a 36 or Lyrik. The actual frame geometry is the same.
