I bought a used set of Cane Creek Zonos SS rims, they are probably a 2004 set. I have been having a lot of problems with the rear freehub and the pawls catching, or lack thereof. The pawls stuck once and no power was delivered to the rear wheel, so I took it apart. Cane creek has great on-line manuals and cleaned it and put some lithium grease in there then put it back together. I rode it about 5-7 hours and the pawls stuck again. I just took it apart again and this time cleaned out the grease and put it together relatively dry tis time, I also tightened the hub pawl spring to give the pawls more spring pressure. Now they work again, but I'm beginning to wonder about Cane Creeks quality and design, or is it just age and I should try to get new parts such as a freehub, pawls, pawl spring and bearings?
