that's my thread!
I went through the heckler vs reign posting thing on both this forum and the SC one. I owned a heckler at that stage but had the opportunity to get a good deal on a Reign. The heckler is awesome. But... the reign is better in almost every way! Lighter, plusher, way stiffer (the rear end of my heckler was a noodle laterally!) and the suspension - no comparison. Climbing, they both almost don't need stable platform shocks but the key difference is that the reign still responds to bumps while under chain tension whereas the heckler didn't. Descending the Reign is also better, really smooths the trail out - it's like you're floating by comparison. The Heckler takes the big hits but in all honesty, not too much of anything else. The biggest difference tho is that the maestro design seems to roll over square edged bumps without loosing momentum whereas the heckler SP tended to get "hooked up".
The only thing that i'm still figuring out is that the reign sometimes can have a tendency to blow through all it's travel unless you have the shock settings just right whereas the heckler was a bit less fiddly - just get on and ride. But I had a no brainer DHX5 coil on the heckler as opposed to a pretty crappy RP2 air shock on the reign - a new shock or some fancy valving would probably fix that. Also the reign sizing was not quite right for me, I had a 19" heckler (large i think) which was bang on. The medium reign was going to be too small so i got the large and it's a big bike! So not quite as nimble as the heckler, bit more of a bus! But I guess that means it's stable as!
Unless you ride in mud all year round and are concerned with bearing maintenance, or think that the SC heckler will make you cool because you're riding a SC, I'd go the reign.
If it was a decision between a reign and a nomad or Blur LT, it'd be a lot closer.
Finally, you can't beat Giant for value for money.
