All right - not too much happened and everyone seems to be stoked to see the new Ventanas (so am I). I think not many of you will be interested in this, but I'll post it anyways - and if it's only for my own records
What happened since my last post?
I decided to get the frame chemically stripped, which seems to be the most gentle method. Maybe I'll have it blasted with very little pressure and aluminum oxide - referring to the foreman in the metal working company this seems to be the best method. This depends on what my painter says - paintjob will be very, very exclusive
Alright - as for the parts you need to know that I was kind of abusing my Salty over the time. I had it in a kind of a XC-trim as well as a 150mm trailbike (5" rockers and 6" fork). But now I want to run it with 4" rockers and a 90-130mm TALAS fork - should work well. I'm also planning to watch weight (a little at least) so I'll be going non-quadbearing and lighter parts...
Well, this is the parts list:
Frame Salty 2794,0
Rear Shock Fox RP23 213,0
Fork Fox Talas R 1850,0
HeadSet CK NoThreadSet 98,0
Stem Race Face Turbine 131,0
Handlebar Race Face Turbine 251,0
Post Thomson 193,0
Post Clamp Salsa Fliplock 44,0
Saddle Selle Italia SLR 135,0
QRs Salsa Fliplock 104,0
Front Wheel 1543,0 (with tire, tubes and all the jazz)
Rear Wheel 1875,0 (with tire, tubes and cassette)
BB Hope 115,0
Crankset Race Face Deus XC 719,0 (with rings)
Pedals Crank Brothers 2 T 240,0
Chain SRAM PC99 268,0
Shifters SRAM X.O. Trigger 225,0
RD SRAM X.O. 205,0
FD Shimano FD-M961 150,0
Cables 50,0
Brake F+R Shimano M-975 756,0 (brakes, hose, discs, mounting hardware)
Makes 11959,0 all in all...
Goal was below 12kg (26,5lbs) - close, but close enough. Grips are not included and I might have forgotten the one or the other item - theoretically the frame should get lighter with the wetpaint and standard bearing - we'll see...
Well, and to make it not too boring some pics of the different builds my salty had to go through:
primeval salty:
big trailbike salty:
last build salty:
