Hi there,
I own a Fox F29 Fork with 100mm of travel, since my frame is designed for 80mm max and I do no like the handling with the 100mm, I would like to reduce the travel of the Fox to 80mm.
It is my understanding that the Fox can be reduced from 100mm to 80mm by adding (or removing?) of a plastic spacer.
However, if I have this done, will this only reduce the travel of the fork, or will the effective height be reduced as well?
Thanks in advance!
Thanks in advance!
