Hi Bikenut,
Short answer = lower your fork and report back to us
:thumbsup:
Long answer = see below.
I know exactly what you mean. I have a bike that only comes alive when it gets faster / rougher / steeper. I also have an old-school 29er that loves the tight and twisty stuff.
Be aware though, you might get some haters telling you that your impressions are wrong, and that new bike geometry is the best, and a fairy dies every. single. time. that someone mentions that new-school geometry not being awesome (ok, I might have exaggerated that last point a little!)
A first question for you, will you be ok with steepening the STA? Can you slide the saddle back on it's rails if you need to?
You can achieve your desired effect by one or a combo of the following:
- raising the rear end, thus steepening the STA/HTA
- lowering the front end, thus steepening the STA/HTA, and reducing the wheelbase (albeit slightly)
- steepening the HA by installing an angle-adjust headset.
- changing the fork lowers from 44 to 51mm
1. raising the rear end - and this keeping your 130mm travel
- install a taller tyre e.g. Bontrager XR2 or XR4 2.6, Maxxis Rekon or Forekaster 2.6
- install an offset bushing in the rear shock
2. lowering the front end
- Installing a fork with a lower axle-crown height e.g. Use a Fox 34 instead of a Pike (this will keep your 130mmtravel, but slightly lower the front end)
- Lower the travel of your fork. This is relatively low cost, and it's easily reversible. What do you have to loose?
3. steepening the HA by installing an angle-adjust headset.
- This will keep your current travel, but will slightly shorten your wheelbase, make the steering quicker and bike more nimble
4. changing the fork lowers from 44 to 51mm
- gregnash & LoneRanger are correct that the effect of changing to a 51mm vs 44mm offset will be small, but it will be noticeable (longer offset means shorter trail which means less steering self-centering, less "stability"). It's an expensive change though. Listen to the most recent BikeRadar podcast for a really detailed explanation - they state that the steeper the HA, the more noticable this effect is.
- If you're at this level of change, it sounds like you'd benefit from a bike that's less "new school", or, that's more XC biased.
