Redline d660
2807 Views 13 Replies 9 Participants Last post by  cordesc
Anyone riding this bike?
http://www.redlinebicycles.com/archives/2009-d660
Curious to know what size frame your on and what your measurements are (height, inseam)?
Also, what do you think a used one is worth? All stock with "50 miles" as the seller claims...
1 - 14 of 14 Posts
Test rode a new one two weeks ago -- a 17" frame. I'm 5' 9" with a 32" inseam. I was just seeing if that size fit me (it did), because I was ordering a Monocog Flight and the current models share very similar geometries.
There is one on ebay from a local bike shop here in MI. I called the guy two days ago and he weighed the 19" frame for me and it weighed 3.5 lbs. Not sure about the stand over but it is pretty light weight.
i have one.
i am 5'10 with 32in inseam and have plenty of stand over. i ride a 17in with 110mm stem and a white brother fluid 110 fork.
prett light weight frame with major tire clearence.
mellowme17 said:
i have one.
Do you think you would fit on a 19 with a 90mm stem? I'm looking at a 19" and I am 5'11 with a 32 inseam...
I know where a 19" 2010 model is..can be had for a good deal..with factory warranty.
PM for details.
The standover will be minimal (it's listed at 31.75"), but the top tube isn't especially long, at 23.7".
As a 32" inseamer, I went with the 17", but lengthened the stock 100 mm stem to 110. Your torso is longer than mine, so the 19" will probably feel good in terms of lenth, if you can deal with the lack of standover clearance. Got a dealer near you where you could score a test ride? Redline is dirtributed by SBS, so lots of shops stock them
What about the Access XCL 29er frame from performance bike? $99 and it is almost exactly the same weight. Probably the best deal out there on a lightweight 29er frame.
But.........only available in 21 or 23" frame sizes right now.
i probably could with out a issue... just might not feel all that great for me... i had a 20in chumba hx2 and that was way to big but i made it work.
D660
21" 2010 Redline D660
I believe the 2009 setup is identical.
My inseam is 34.5", floor to crotch w/cycling shoes.
Standover is 33.25" measured(where I actually stand), spec is 32.99" spec.
I've saw a new 2010 go recently for $800, but $1000-$1100 would be more typical (again new).
I have a 32" inseam, 5'10" and ride a 19" mono9 frame (same geo as the flight, etc) w/ a 100mm stem.
I just ordered a 2012 D660 19". I"m 6' with ~34.5" inseam. I think I will be happy. :)
1 - 14 of 14 Posts
