A little article my wife wrote on recovery
http://pedalmag.com/index.php?module=Section&action=viewdetail&item_id=18576
Yep.rockyuphill said:That makes more sense than the column in the print edition of Pedal which was titled Recovery but was actually about a Racing Clean initiative. :skep:
This is the link I used to learn a bit more about the Rusko test, but I think as far as RHR goes it is just counting your pulse for a minute to see where you're at? You'll usually find a normal range, and then when it's elevated or suppressed you can usually learn (trial and error) if it means you are under-recovering/resting or getting sick, etc.Johnny K said:LMN, can you elaborate on the RHR method she talks about in the article. I have a pulse oximeter and would like to try this more accurate way of tracking HR in the AM.
A recovery drink is the best way to get nutrients in you quickly.rydbyk said:How important is a good recovery drink post ride?
Any recommendations for a product that works well in your opinions too?
do we have information what falling on your face does to the rusko test 2.5 days out from nationals?miss rides a lot said:This is the link I used to learn a bit more about the Rusko test, but I think as far as RHR goes it is just counting your pulse for a minute to see where you're at? You'll usually find a normal range, and then when it's elevated or suppressed you can usually learn (trial and error) if it means you are under-recovering/resting or getting sick, etc.
http://www.ilog.ca/help/Rusko_Heart_Rate_Test.htm
a) I did not fall on my facewhybotherme said:do we have information what falling on your face does to the rusko test 2.5 days out from nationals?![]()
Seems there might be a story we need to hear about.............miss rides a lot said:a) I did not fall on my face
b) No.
