A winter of mud has taken it's toll on my 240 rear hub. The driveside bearing in the hubshell is seized which is an easy enough fix once I acquire the star-ratchet tool to get access to it.
Unfortunately the inner bearing in the freehub is also seized. I'm having trouble figuring out how to gain access to that bearing to replace it. Is the done thing just to replace the whole freehub?
DT Swiss's hub overhaul instructions mention a 'reconditioned freehub' which makes me think it is possible to replace bearings in the freehub. Does the star-ratchet unscrew from the freehub as it does in the hub body or do I get at it from the cassette lockring end? I had a look at what would be involved in that approach and I can't see how the seal on the outer end of the freehub wouldn't be destroyed in removing it.
