Ive got a recon 351. Ive got it set at 65 pounds to get proper sag, 10 less than recommended.
When i clean the stanchions after every ride, I notice that i am only using 80 mm of travel from the dirt lines. This is on xc rides with 1 to 2 foot jumps at around 28 mph (says the cellphone gps) on the descents.
The shock has 130 mm of travel. At the most, i use 100 mm. If i really pusuh down on it, i can make it do 110mm. If it let the pressure out of the shock and collapse it, i get the full 130.
Is this normal? Is this the bad side of an air spring with a progressive rate? Maybe, i dont need a bike with more than 120 travel after all? Im just thinking out loud. Thoughts welcome.
Old school ridgid rider just discovering shocks.
