That sounds like an extremely unfortunate situation. Good luck figuring that out!
Now that you say that, I did fix a rear flat and had the bike upside down for a few minutes with that. I'll try that. Thanks a bunch.Moodrid said:I had this happen as well as loss of travel.What seems to cause it is turning the bike upside down while the pop lock is on.I had it happen when I first got my 351 and as I rode it it fixed itself.Now Like a dummy I did it again.I will ride it now to see if it works itself out once more.Seems like the oil get trapped away when doing the if only while fixing a flat.My advise is set the pop lock on alittle bit as you should have motion control and ride it to see if it woeks itself out.It may take a few rides but it worked fine for me before till I screwed it up again.
