Hi All,
I will be changing my Chainring configuration as follows for a 104/64mm spider on a Specialitiés Carmina Crank. The rear cogset is 9-Speed 11-34T.
Inner: Blackspire Chuck Ring 22t (Stainless Steel)
Middle: Surly 34T (Stainless Steel)
Outer: Specialitiés Chinook 7075-T6 Al 46T
Is there any particular chain you would recommend for the above configuration? Will any 9 Speed chain be sufficient? Or are there some that will shift better with chainrings that do not have shift ramps and pins?
My current configuration uses Race Face Al Chainrings (24-36-48) with an XT 11-34T cogset and a KMC X9 SL Chain. The upshifts (small to large cogs) at the back aren't that smooth nor quiet and I have problems at the front too which I think is due to the bottom bracket axle being too long (122mm). I will also be changing the BB to one that is 118mm.
I have a similar configuration (no shift ramps and pins) on my old rigid bike which has a 7 Speed cogset (13-34T) and the front shifts very well.
Thanks, Michael.
Thanks, Michael.
