Bikeyoke.
Get the oneup remote or a wolf tooth light action. The oneup requires more leverage that some. All posts have slightly different actuation forces. You can see that on Wolftooths compatibility pages.On a new bike (so new cable and housing) I have a oneup v2 180mm (using a different remote) and I have been very unimpressed. The main issue is the remote is impossible to push if the post is weighted. You can push to the point you'd think the cable will break and it will not actuate the post. Lift your weight and you can push the remote, but this is a pain in the ass and really annoying on a ride.
Reading though the oneup thread, it seems like alot of people have the same issue and it was not really resloved.
Additionally, the post feels gritty, not very smooth and just bad overall compared to my last xfusion post that had 1200 miles.
One up was helpful and sent a new cartridge but there was no change.
I pulled the post again and this time checked the bushings ( keep in mind this is a brand new post with maybe 30-40 miles on it). The grease looked like nasty dried out wheel bearing grease.
I'm cleaning and relubing it now, but I'm getting very tired of battling this post and tempted to send it back and get a refund.
I wanted the oneup for the lower overall height due to my new bike frame but I'm amazed how poorly this post works.
Kind of a rant, but what other posts work WELL for $200 that are not crazy tall? Xfusion, PNW, transx.....?
Tell me about this please. What do you mean?They can also be readily serviced in the field
Interesting problem, especially considering you have replaced the cartridge. I have OneUp V2 droppers on two different bikes, work great and they have been problem free. I would not think a lever would make a difference with that particular problem, but sounds like an adjustment issue with how much cable is being pulled. What kind of lever are you running anyway?On a new bike (so new cable and housing) I have a oneup v2 180mm (using a different remote) and I have been very unimpressed. The main issue is the remote is impossible to push if the post is weighted. You can push to the point you'd think the cable will break and it will not actuate the post. Lift your weight and you can push the remote, but this is a pain in the ass and really annoying on a ride.
I guess they all have a bad day though. I just sent back a brand new Revive 213. It would not drop if the seat post binder had more that 3 NM of torque. Air was at max psi. BTI, the US distributor said to send it to my dealer and have the dealer send it to them. F-that! I returned it. Both the OneUp it replaced and the final replacement Fox Transfer drop just fine at the recommended 5NM.BIke Yoke dropper post are considered some of the best. I use one on my personal bike. They can also be readily serviced in the field and carry a two year warranty.
X fusion makes some pretty dialed stuff. I would never say if they can do it anyone can, but I get your point. In my experience they make some stuff that's more reliable than the big names. It's only their really cheap OEM stuff that might be subpar. I have a metric HLR from 2013 that has original damper seals, and even the foot nut crush washers are original. I service the damper whenever it seems time, same with lowers oil. Dust seals is all it's needed and it's seen a ton of use. It's by far the most reliable fork I've owned. That said, I believe x fusion and brand x are basically the same post. I know I heard somewhere that most of the 200$ range posts are all really similar in regards to action and average reliability.Thanks for the suggestions. More to consider.
The lever is a possible contributor. My only concern is the lever is IMPOSSIBLE to push weighted. I'm tempted to try another lever, but I don't see it helping if I can push this one as hard as I can and it won't actuate.
For those (manufactures and individuals) who think it's acceptable to have to physically unweight the post before dropping, that is absurd. My last xfusion worked perfectly. No matter body position, weight etc. If they can do it, anyone can.
I don't think anyone is saying it's strictly necessary to unweight things, but it doesn't hurt and it certainly extends the usable life of whatever part you're stressing. If you are loading the post with your full body weight, there is more stress on the mechanism that releases the dropper than if you only have a portion of your weight on it. Should it work? Of course, but expecting it to last as long and function as well as it would if you reduced the load a little is foolish.For those (manufactures and individuals) who think it's acceptable to have to physically unweight the post before dropping, that is absurd. My last xfusion worked perfectly. No matter body position, weight etc. If they can do it, anyone can.
