1 - 2 of 2 Posts
What frame are you running and is this for front or rear?
Regardless of your response, the answer to your question is: the widest rims your bike will fit for both front and rear are the best.
Most modern trials bikes were designed for a ~47mm wide rear rim. You will have difficulty setting up brakes on narrower rims.
I recommend for both front and rear:
Echo 48mm
And if your bike can't fit those for whatever reason, then:
Alex DX32 (36mm wide)
Both are found at Webcyclery
1 - 2 of 2 Posts
