Going through the same procedure right now. Here is the list of bearings I found deeper in the forum :
(ENDURO BEARINGS)
2 Rocker Tip Bearings 398 LLU MAX EE 8*19*10mm
2 Seat Tube Bearings 3801 max LLU 12*21*8mm
4 DW Link Bearings 3802 LLU MAX 24*15*7mm
Does anyone have experience with removing the bearings? Those two rocker ones seem easier, i suppose i can remove them with a threaded rod and some spacers, but should i press them in or our or it doesn't matter?
Where i'm lost is the rest of the bearings which sit in the frame and i can't press them from inside, should i use a tool like this? ( https://www.youtube.com/watch?v=WqNBbntW_lE ) Or is it possible to hammer them out from the other side of the frame?
Thanks for any feedback, i am new to this high end home maintenance and am quite afraid not to damage my frame.
