I don't seem to be very good at determining what I need to set in terms of the suspension feel of my bike. I'm just not sure how to set according to speed, feel, etc.. and how to diagnose things about the suspension that I don't like.
I think I know what these settings do:
Rebound - the speed at which the shock returns to it's extended length
Compression - the speed at which the suspension compresses
Floodgate - the force needed to open the floodgate and allow the suspension to compress
Positive air - for setting compression force
Negative air - for setting rebound force
So with all of this, how do I know what needs to be set and to what setting? Is there a guide or is it just hit and miss?
ALSO - Question, I have 2 shock pumps. Is it common that the readings might vary a bit between the two? Like one says 180psi where the other one might be 175psi but there is really no way to know for sure which is correct?
