What kind of pump are you using. You'll want to make sure that you are using a 'loss-less' pump that disconnects the head without losing air. Try setting the negative (bottom) air chamber equal to the postive (top) chamber pressure. Air pressures should be around 60% of your body weight to get about 20-25mm of sag when you sit on the bike in riding postion.
I hope that helps. Negative air pressure helps overcome initial stiction.
