I used to have the rebound set full to the slowest position on my Rock Shox Reba SL, but I started riding more aggressively so I loosened it up with a few turns which felt good just pushing down on the bar. On the ride, it felt a bit too pogo-stick like. I later discovered, while I was riding through rough rocky downhill sections and after got a flat, that the knob was totally gone when I flipped over the bike. I'm guessing that it's not secured on and is like a valve cap? Can I get a new one anywhere cheap and convenient? Is there any elegant way I can secure the new one, so I can adjust rebound to be faster and not risk losing it again (I'm thinking about just simply taping it).
Also, I'm guessing 30 psi is too low up front with a Reba SL for rocky descents on a hard tail? I tried to patch the tube and noticed it was a "side snake bite", the lower inside with a massive slit (1cm almost) and the upper tire side about half of that size. I determined that the tube got smushed so hard on one side of the rim that it flattened out like that and the force between the rock, tire, and rim sliced through both layers. It was an immediate flat and it was really hard to determine the source of the leak with a portable pump since the air leaked out immediately upon pumping. First time I ever got that kind of flat, but I was experimenting with lower pressure. I used to run up to 40psi up front.
