I just got my first Reba SL '06 from Ebay this week. It was never used other than being mounted on a new bike. It arrived very clean, unscratched, etc. I had it mounted at my LBS and took my first ride on a mostly rooty hilly trail this morning.. a good maiden test run trail.
All was well until I started hearing this air escape from the right fork leg upon each compression after the first mile. It seemed to hold compression fine, I checked it out but wasn't able to really see anything wrong. So I rode for 2-3 miles and it stopped making the air escaping noise. I had not clue what made it stop.. so I continued and about 5 miles later the noise returned.
Once I got home after the ride (about a 12 mi. ride) I went over the manual and rechecked all the settings: floodgate, neg/pos air, rebound. All set to my weight specs.. but the escaping air noise still occurs upon compressing the fork.. even while standing still in the garage.
I scoured the web (SRAM/Rockshox site useless) about this and found some posts that reported the same findings but no root cause or solution was described. Some owners claimed "Yeah, mine does that too".
Obvious questions I have.. Is this normal ? Should I be concerned ? Where may the air be coming from ? The neg/pos chambers had 100+ lbs each when I checked them after the ride.. so I don't believe I am losing air.. perplexed to say the least !! :madman:
Any troubleshooting tips etc would be appreciated... as you know.. I am not the orig. owner, so Warranty is void without original invoice.. so I'm on my own !!
