Let me start this off by saying I am not having any problem with my fork whatsoever, I just abhor the lack of adjustment from the Motion Control damper. It goes from open to locked out pretty easy, with really not much change on the middle clicks. I would like to have some more control over the damping.
The fork is a Reba RL 120 that came stock on my Fuse Carbon Comp. The amount of travel is fine, I'm not struggling with stiffness or flex, and I picked up some bottomless tokens to add to the air spring side to help me be able to run a little lower pressure and not blow through the travel (that helped).
I am considering getting the Charger 2 damper upgrade (cost about $200, I can install myself) which will give me more low speed compression control. Before I order it, I thought I would ask if there was any reason I should consider replacing the fork with some thing like a Pike or Revelation, those seem to be available around $500 - $650 for the 2019 models. Other than the 35mm stanchions, just wanted to know if I would be missing out on anything else. I had a Pike on my SC 5010 and liked it, but it wasn't life changing.
A little about me, 190lbs riding weight, dry-rocky-desert single track of AZ, mostly riding XC/trail 90% of the time. I travel to ride "bigger" stuff occasionally but a lot of that is out of my system now after 30+ years of riding - I'm pretty much calling the limit a 4' drop to a transition at this point - but again that type of riding is the exception to my normal stuff.
Any thoughts?
Any thoughts?
