Just received my Reba Race 29er w poploc wich will be mated to my Mooto-X YBB.
Now I know this has been discussed a few times before but I'd appreciate some advise on solving the floodgate knob / dowtube issue. I knew upfront this could be an issue and I'm prepared to deal with it.
I just measured it and with using a CK headset I will have to stack 4-5 mm (approx. 0.2 inch) to have the floodgate knob run free under the downtube. Would it be possible to put a 4-5 mm shim between the crownrace and the baseplate? I noticed the thicker area were the baseplate goes is quite high on the Reba. I'd prefer this over a higher stack headset since the CK is already here. What's more, I doubt another headset will give me the 4-5 mm extra I need.
I know I can always convert to the Sl with internal floodgate adjust and then don't need the extra stack height, but then I'd probably lose the poploc option wich seems usefull for my kind of riding.... Anyone know if it's possible to have the poploc option with internal floodgate adjuster?
Your input is much appreciated!
