Ok my '08 Reba is seriously starting to piss the hell out of me. It started with a leaking + air because the upper left leg was bone dry. Easy fix, I was happy about it yet my fork felt easy to bottom out. I ramped up the + air and it seemed fine but squishy. Then my Floodgate knob starts leaking, I add some spacers to crush the o-ring and it seems to hold. I also unhooked the remote lockout spring in teh Moco while I was working of the fork and installed a manual lockout knob. I changed the oil while it was all open, reinstall everything and it looks good to go but I noticed it isn't as squishy or easy to bottom out as before I changed the oil, which seemed fine but I wanted to look after it, thinknig I put back too much oil.
So today I finally got the time to check out the oil level. I remove all + and - air first and notice the fork doesn't get all the way down. I'm surprised but it seems to fit with my "too much oil theory". So I loosen up the right upper cap. I expected to see the oil close to the top but it wasn't. I open the left upper top cap too and with both upers still open I tried to compress the fork. I can get full travel, but when I release the crown/lowers, it goes back down 1 extra inch.
I had a hydro lock last year and this doesn't look the same, I shouldn't get that last inch if it was a hydro lockout, right? So I'm wondering what the hell is going on with my fork this time. In a way it's not too bad as it really ramps up the last inch and prevents bottom it out but it's weird. I don't think the Reba has a bottom out bumper so maybe some kind of suction in the lowers is causing this? Dry o-rings maybe?
Any idea is welcome.
BTW, I'm planning on rebuilding everything and changing all the o-rings, just waiting for the order to arrive... For now I'll close everything back so I can race on sunday and I'm looking for a solution to do early next week.
Thanks folks and let me know if riding it may cause damage.
