Just got my new Reba in. On the back of the arch are four little tabs, two at the top and two at the bottom. Are those there to keep your disc brake cables from sliding to the side when you zip tie them to the arch? If so, does it means you should run your cables behind the arch and on the inside of the shock? Any insight would be greatly appreciated (pics even better!) Thanks.
