some hubs have a little play in the bearings untill you put the wheel on the bike and tighten the skewer. its trial and error, you tighten the bearing nuts untill its slightly loose, put the wheel back on the bike and check for play, if there is none and the wheel spins freely you're done, if there is still play, take it off and tighten a little more (not too much).ScottJensen said:what do you mean while on the bike?
