Rear tire not centered?
3321 Views 5 Replies 5 Participants Last post by  DeeCount
I just noticed my rear wheel is not centered on my Trance. It sits more to the left side. I can also see it doesn't line up with the seat post. I guess they have to move it to make way for the 12 speed cog?
Can anyone confirm my observation?
Just took a quick pic last night, it doesn't show much, but can still be seen, look at the red lines I squibbled...
Tire Wheel Bicycle tire Automotive tire Bicycle wheel rim
1 - 6 of 6 Posts
It’s likely your wheel is not dished properly. I like to dish the wheel while it is in the frame to account for the fact that frames are not perfect down to 0.1mm. Most wheels are dished in a wheel stand.
  • Like
Reactions: 2
Does it wobble when you spin it? Is there play in the hub?
No it does not wobble. It's straight. No play too, though it developed slight play after a few rides, I removed the wheel and checked the where teh wobble is coming from. It was from the end cap, the bearings seem to be tight. I tightened the maxle and it seems to have solved it.
Every MTB I've had is like that (though not a big sample size). The more important question though is where is the centerline of the wheel is in relation to the seat tube. Swingarms and chainstays can be asymmetrical and make it look as though the wheel is not centered. As long as the wheel is inline with the frame (seat tube as reference point) then there shouldn't be any tracking issues. Even if it was off by a few mm I bet you'd be hard pressed to notice in regular trail riding. You'd notice more when you tried to wheelie or manual and the bike kept trying to lean to one side.
  • Like
Reactions: 3
1 - 6 of 6 Posts
