1 - 12 of 12 Posts
· Bike Addiction
If no one answers, I called fox and bought from them. They had the info in their data base. Mine was an 09 XC Comp X-Fusion to an Rp2. I do believe the X-Fusion is 12mm and the Fox shocks are 1/2". But double check that. Read my DISCLAIMER signature. I'll throw this link in even though its 2 different bikes. You might get something useful out of it.
http://forums.mtbr.com/showthread.php?t=595271
· Bike Addiction
I THINK that the top is a reducer with spacers on each side to fit bike mounts. Sorry I can't remember exactly. Its been a year since I swapped mine out.They sent me top and bottom and extra bushings. I remember I had to swap both ends.
Edit: There is a member on here(mtbiker4life) that has a bushing tool for sale that was alot of help too.
· Registered
Hey, OK so I went to Suspensionwerx here in Vancouver and they told me to use 803-03-088 instead of the 803-03-100 because the steel bushing lasts longer and protects the shock better. Also the 803-03-030 does NOT work on the top linkage. It fits but it will damage your shock. Just in case someone else needs info!
1 - 12 of 12 Posts
