1 - 10 of 10 Posts
Has anyone replaced the stock rear shock bushings (I am running DVO Topaz) on their Balance or Riot? Curious about adding some extra shock sensitivity. If so, is there a kit readily available or is a hassle to track the parts down?
Discussion Starter · #3 ·
RWC does some nice kits, I run them on my riot and I really like the difference
They don’t have the Riot or balance listed...what kit did you get? Install yourself? Any troubles installing?
Thanks for the help
I put a new X2 on my Balance with a combo of the mounting kit they gave me and the stuff that was on their with the CC DB Air CS, but curious if there is something nicer. I heard needle bearings aren't sturdy though and the this big volume air shock is already so sensitive I doubt there will be any benefit.
Interesting...this is the first time I've heard of needle bearings for a rear shock but they sound like a great idea in theory! I'm building a 2016 Balance with a MRP Raze and expect it to be a pretty smooth suspension as is but if these bearings offer any performance improvement and are fairly reliable I think I'll have to give them a shot. Thanks for bringing these bearings to my attention! :thumbsup:
In to hear other experiences with needle bearings and CBF suspension setups...
Discussion Starter · #6 ·
From what I’ve found doing a bit of research is that using these needle bearings instead of the stock bushing eliminates the initial friction to get the shock moving so it makes the shock more sensitive and more supple.
As far as durability, again from what I’ve seen/read, people are getting longer lifespan out of the needle bearing than the bushing with a little care depending on what kind of conditions you ride in.
Wasting your time and money putting needle bearings on either riot or balance. There is almost no/zero moment at the bushings. They do work work well on suspension designs that have a lot of movement.
https://www.youtube.com/watch?v=0TIXSZDFv
Discussion Starter · #8 ·
Good to know. I figured there was movement at the back end where it attaches to the swingarm.
THIS! Thanks for saving me the time to explain this. And yes, for shocks that DO have a lot of rotation at one or both eyelets, they are a great idea (Santa Cruz VPP bikes really benefit, I can assure you).
Have FUN!
G MAN
Thanks for the help
I got the NBKRWC3556 kit for my riot, just shoot them an email and they will let you know which kit you need, No problem installing either
1 - 10 of 10 Posts
