I have a small play in Maestro rear suspension (Giant Anthem 2) - I understand, it could be loose bolts, worn bearings or worn bushings.
I had a look at the bushings, and there is a thing I'm now quite sure about: the bushing is sitting tightly in the eyelet of rear shock, two alloy mounting pieces are inserted into the bushing tightly as well, the mounting pieces are inserted into the rocker arm and screwed tightly by a bolt. Now, as suspension moves, the rear shock has to compress and expand, but also rotate a little bit. This is the part I'm not sure - where the rotating movement happens - (1) bushing against eyelet? (2) mounting pieces against the bushing? or (3) the mountng pieces against the rocker arm. Similar question about other end of the shock.
