Just picked up a new monarch rt3 from push and looking to install this badboy... I was looking for the torque specs and found this posted on the ibis site.. "All forward shock mount and pin bolts: 4 Nm (3 ft·lbs) with blue Loctite"..
So 4Nm used for both the front and rear bolts?(just making sure im reading this right).. If im using stock bolts-- id assume ibis used locktite-- so would i need to reapply it or is the already coated stock bolts fine how they are?
