No worries...sdr08 said:I wouldn't get too excited as I have a funny feeling it's a No.1.
Have you got yer CCDB yet?
I´m not 100% sure, but ´ll suppose that there`s 1mm difference between those numbers (so they means alignment in mm`s) and different ones are -2, -1, 0, 1 and 2.Kbrembo said:No worries...Is there much difference in the 0,1,2 etc?
So will this make him run in clockwise or anti-clockwise circles?norcosam said:I think all the hangers are the same its just the roll pin hole is in a different place(fore and aft)The number tells them where the hole has to be.
No - the number on it sets the alignment in the vertical plane (moving the dropout up/down). Sliding the dropout back and forth sets the alignment in the horizontal plane - when it is aligned a hole is drilled in the frame. Aligning the frame hole with the hole in the RADO ensures alignement is correct when the RADO is replaced.norcosam said:I think all the hangers are the same its just the roll pin hole is in a different place(fore and aft)The number tells them where the hole has to be.
