My crystal ball says a whole new wheel is in your future.
You are the one with the wheel. The model number should be stamped on the hub shell. Use that to find the FH body you need.brankulo said:it is shimano wheel. could yo be more specific on the hub?suggest which one to get please. thanks
Ya didn't look hard enough. Try here -brankulo said:ok so i have wh 765 stamped on rear hub. based on that and the link provided i found out that i need following: Y-3C0 98010 COMPLETE FREEWHEEL BODY W/RIGHT HAND DUST CAP.
where am i supposed to purchase this part. lbs doesnt carry it, i searched online for hours with no luck.
thanks
You did not look very hard.brankulo said:ok so i have wh 765 stamped on rear hub. based on that and the link provided i found out that i need following: Y-3C0 98010 COMPLETE FREEWHEEL BODY W/RIGHT HAND DUST CAP.
thanks
