Rear FS mudguard from inner tube?
1750 Views 3 Replies 3 Participants Last post by  TraxFactory
I have seen DIY mudguards for FS bikes from old inner tubes. Would like to know the most effective way to build this, as I have given up on rigid options that fail when the dropper post is down. I seem to recall that a section of inner tube was connected to chain stays & saddle. It would flex with suspension, and HOPEFULLY not get snagged against the rear tire when the dropper is down & the suspension compresses.
I have a large frame with about 140mm rear travel, & the good ol' mucky nuts mud flap attached to the saddle kept getting mashed against the rear tire.
Share the DIY wisdom? Thnx
1 - 4 of 4 Posts
Shove a Marsh Guard in?
Not a great picture but depends if you are trying to keep crap away from a shock/linkage or yourself.
Bicycle Wheel Tire Bicycles--Equipment and supplies Bicycle wheel rim
Thanks, but as stated above: Looking for "how to" on the DIY inner tube mudguard.
you mean like the dropper flapper thing?
Google dropper flapper search
  • Like
Reactions: 1
1 - 4 of 4 Posts
