1 - 20 of 108 Posts
I know I have seen this before, but I don't even know how to search for it.
It's an adapter that either fits in a horizontal dropout, or just around the hub which allows use of a rear disk for those who don't have the tabs. Does anyone know of what I'm describing? Thanks.
Yes, A2Z adapters has one for just about anything you could inagine. Some are multi use and will take some playing to get the brakes to line up but, they work. :thumbsup:
War machine member
I haev in my possession a Woodman disc brake adapter which uses a proprietary hub that will only work with verticle drop-outs. It worked great for me on my RM Blizzard, but I sold the bike (with rim brakes on it) and kept the adapter. I'll try to post pics later.
prawny
A2Z disc brake adapter - pics
a few years ago... after converting an older voodoo wanga frame to ss, i decided to add discs.
here're a couple pics showing the A2Z installed.
remarkable, to me anyway, are the way the thinner plate bends around the frame in order to snug up to the thicker plate (by design?), and also you'll see via the side-view pic that there is a movable "flap" -- during installation you rotate the flap into contact w the seat stay (in order to prevent the adaptor from slipping?).
anyhoo... the system worked just fine for me.
epilogue: about a year after converting the voodoo, i was fortunate enough to get a wonderful custom vulture ss frame, which i've been happy with since. but looking at the voodoo pics now, makes me long to build that bike back up again. you can never have too many bikes yes?
~g
I have a brake therapy disk brake adapter that runs from your brake boss. It is not the lightest thing, but I have not had to adjust it in 2 years. Built very well and their customer service is excellent. I think it is 2 or 3 times the cost of the A2Z. I will take a pic of it tonight.
I've used several disc adapters, it's taken me a while to get all the pics collected.
This is the cheapest one, and it works reasonable well on frames with flat dropout (not Breezer type dropouts).
The Brake Therapy adapter was one of the 1st, and is still a decent solid device, not cheap, and you need an adapter on the hub as well.
The Woodman Adapter is similar to the BT version, but it's designed to work with thier special hub. You can use a Shimano hub by shifting the axle. I liked this one the best, easiest wheel changes.
AtomLab adapter is meant for horizontal wheel mounts only, originally for BMX bikes. Axle needs to be shifted, and it helps to add a torque arm.
Pauls version (another BT copy) only works with their single speed hub.Wheel removal is a bit of a pain, because the adapter is permanently attached to the hub.
This is the Specialized SharksFin adapter from their early FSR frame, and it has been used to convert many bikes to disc - our lbs used this for several Kona Hei Hei disc conversions, I have used it on a AMP B4 rear triangle. It requires you to drill a hole near the dropout to bolt on the adapter.
Then we can get Getto:
Modified from a BMX stem.
Made from scratch - on a Santa Cruz Superlite.
A hacked Woodman adapter to fit an old Catamount.
moose27e said:
Does Anyone know what hubs can be used with the Brake therapy setup? The page for it has a list http://www.therapycomponents.com/btmoreinfo.htm But it is not specific on what type of hubs (i.e. it says "Shimano XT" is that ALL XT hubs? centerlock or 6 bolt?) Thanks!
The adapter work on any XT hub that has 10mm axle, which is currently all XT disc hubs (as far as I know). Some re-spacing may be necessary on the centrelock hubs. It'll work on most LX and Deore hubs too. I found that the Shimano conversion was never perfect, I could never get the hub to spin as smoothly as the stock cones.
As noted above (I forgot about this thread..) I couldn't get the A2Z to line up. I guess I never looked at the picture with the 'flap' rotated around as such. However, the junction of the chainstay and dropout on my Voodoo Bantu ('98 I think) did not allow me to rotate the device clockwise around the skewer far enough to bring the caliper down completely over the rotor. I'm giving the adapter to someone local this week, as I've changed bikes, so I'll let you guys know if it works for him.
moose27e said:
Thanks for clearing that up! So then do you recommend the DT hub(s) or Chris King?
Sorry - been on holiday (biking at a place with no cell coverage or internet access!)
DT or CK, your pick. Both are good hubs, and their current page lists both as current conversions (both worked perfectly on my bikes). The DT conversion does not require pre-load adjustment, unlike the CK hubs.
Also, thier most recent page (http://www.therapycomponents.com/hublist.htm) indicates that as far as Shimano is concerned, they only recommend the 6-bolt (ISO) hubs.
x6thgearwideopen said:
How do they fit that adapter inside the stays withought making them wider? Do they replace the nut that keeps the left cone in place?
They are all different.
Brake Therapy replaces the outer locknut or hub-end with one that allows the adapter to fit
Woodman requires you to re-space the axle to 130mm.
Pauls replaces the outer lock nut with the threaded adapter plate.
Atomlab says to pry open the dropouts (or re-space the hub a few mm)
The others do not interfere with the dropout.
nuck_chorris said:
Lets talk more about that ghetto method of yours
What do you want to know. The CS were 22mm, bmx bars are 22mm. Hacksaw, file, drill & tap. Thats about it.
1 - 20 of 108 Posts
