1 - 18 of 18 Posts
I'm having a problem with my rear derailluer cable housing. where it goes through the cable stop on the top tube. Actually, they are not stops, it seems to be a pass through for the cable. but it wears out the cable housing were it rubs during suspension travel. does anyone do anything else to fix this. it is an 09 asr. I was thinking of making some sleeves so they could be used as stops.
Not sure if this will solve your problem, but Yeti (and im sure other manufacturers) sell some cable protectors on their site. They are designed to keep the cables from rubbing on parts of the frame. I just ordered myself a set (pack of 3)
Here is a link
http://store.yeticycles.com/store/show_product/341
Discussion Starter · #6 ·
Here they are. They are Jagwire pn# CHA013. They are specified as Cable Guide Stopper (Converts Open Loops to a Frame Stop). 1 problem is that they are for 5mm cables but i just put a small peice of heat shrink tubing on it . I rode sunday and it worked flawless.
I also uploaded 2 pics of them on my bike. I think it looks clean.
I've seen those guide-to-stop adapter things, I just can't for the life of me understand why you'd want to do that. Shifting too good, and you just want your cables dirty? Such a weight weenie that you're willing to add 10g of stops to save 8g of housing? Like getting your leg hair in cables?
I just can't see an advantage to this.
Discussion Starter · #11 ·
OK, here is the long reasoning:
I had a problem with the cable housing getting worn were the housing passes through the housing guide. I happened on the back side of the housing were it was not exposed to my eyes and caused the cable to rub on the frame. And before you go and say i should check that, This shouldn't be an issue. Thats why I did what i did. I serves a purpose. Im not a weight weenie. It also rubbed the paint off and and made the frame look like crap. I love my Yeti and will not bash it or the company, they build bad-ass bikes but this should not happen. Thats why.
So to anyone else who has a problem with what i did then don't open this thread or __________AYHSMB!!!!!!!!!
sincerly
Mike
:D
Discussion Starter · #13 ·
eatdrinkride said:
For those of us who didn't actually have a "problem" with what you did, but rather were inquiring as to why you did what you did, do we too, still have to suck balls? (it's too late for me to not open this thread)
:D funny!!
I hope there is enough info for any one to do this mod if they feel the need to, as its working out well for ME.
1 - 18 of 18 Posts
